Carter carbs
Started by rick, March 12, 2013, 06:51:40 PM
rick
What size carbs came on a 426 hemi 650or 750 cfm
Rolling_Thunder
I read somewhere they were rated at 570cfm -  I have the stock specs on jets and rods if you need it ---   just let me know what carb numbers you're looking at
Speedfreak
Quote from: rick on March 12, 2013, 06:51:40 PM
both were 625 cfm, Carter AFB, back had choke, front did not
The reality is that the OEM Carter carbs never got an advertised CFM rating....all quoted ratings are just a WAG.
rick
Rolling_Thunder
If it matters -
Primary throttle bore = 1 7/16"
Secondary throttle bore = 1 11/16"
charge69
The Carter AFB's on Hemicars were rated at 625cfm each, at least for '68 thru '71. Not sure about '66 an '67 but I think they are the same.
