Losing the fuel smell
Started by Dino, February 14, 2013, 01:15:48 PM
This may improve once I install the TQ but I'm a bit pessimistic.  The car runs great but after a 5 minute drive I smell like raw fuel and exhaust fumes and I'm getting tired of it.  My lungs have been tired of it for a while so I need to get this fixed.
The exhaust fumes were reduced once the header leak was fixed but it's still leaking somewhere, the collectors likely so I'll swap the gaskets for Percy's this spring.
So what is the solution for the fuel smell?  Is it the carb?  Will I never get rid of the smell unless I install efi?
Do I need to cut out the variables and replace the entire fuel system?
Please help DC-Com Kenobi, you're my only hope!
six-tee-nine
Vehicles with a carb will always smell after standing for a while. But in most cases (or my own expierience) the smell goes away when you drive it and the engine warms up.
If not there might be something wrong. However, you might need to determine if it is unburnt fuel (vaporised) or exhaust gasses your smelling. As you said, leaking exhaust manifols can give you a nice headache from the fumes (or from trying to fix them).
Oh and dont forget old cars need to have gassy smell
WHITE AND RED 69
How rich do you have the carb set? Are you leaking fuel? If you were going to swap the carb anyway I'd swap it to the new one and see if it helps any. Or lean out the current one just to see if it cuts down the smell?
Have you thought about adding a return line to the tank? That might help.   :shruggy:
1969 Dodge Charger R/T
1999 Jeep Grand Cherokee
1972 Plymouth Duster
Ok I can see it smelling a bit after sitting, that makes sense.  However my car never sits for very long.  Even when I drive it all day, every day, it'll still make me dizzy.
So if the carb is rich, which it is, it's probably just throwing out the raw fuel with the exhaust fumes and if the exhaust leaks at the collector...then I'm basically sitting in an exhaust/fuel vapor mix...that ain't good.
I'm reading up on efi and saw the need for a return line, I guess it would be wise to install one regardless of fuel delivery system so I'll do that.  Do I need a new pump for that or can I use the stock pump?
I need to get busy on that TQ, I cleaned it all up but haven't done the actual rebuild yet.  Once it's on and the exhaust leaks are fixed it may solve the issue.  I hope...
Thanks guys.   :2thumbs:
super77se
theres a number of reasons you could be smelling raw fuel
old plugs / ignition needing attention
stuck float / dumping fuel / flooding
rich mixture
fuel leak somewhere
missing grommets somewhere allowing fumes inside
door seals/trunk seals
tank vent / unvented gas cap
open element air filter
im sure ive missed something but , like said above, carbureted cars just stink sometimes
I always have my windows down - not because of that but it helps! Check the trunk and trunk seals. These cars seem to have some magic vacuum that will suck the exhaust right out of the pipes and into the car. Fixing the header should have made a decent improvement since it's in front of you. Gas smell is probably due to your current carb. Remember when it was at my garage and almost ran us out. My eyes were burning for 20 minutes! All of my cars seem to run rich at idle but not nearly that bad. When you swap carbs (assuming it's right) it should solve a lot of the raw fuel issues (and get you better mileage).
Quote from: Troy on February 14, 2013, 02:12:52 PM
Oh yeah!  I had a headache for a day or two after that.   :lol:
I did manage to get it a little better but not a ton.  The header fix sur ehelped but I never tought about the trunk issue.
Windows down and keeping it moving sure helps but oh my when you step on it, it's like half of the fuel goes in the carb and the other half gets thrown in the cabin.   :eek2:
Quote from: super77se on February 14, 2013, 01:51:46 PM
rich mixture
fuel leak somewhere
I better check the firewall, I'm sure I've got this stuff wafting in somewhere.  Funny enough, even with the rich mixture the plugs are a nice tan/brown and dry.
 all whats been said  :yesnod:
also , in picture below  , check B  that the rubber pipe is not disconnected or split some how , also with A  i extended the pipe with suitable rubber hose it would  vent out side underneath the frame rail, not inside , bit of over kill may be , but i'm nutts like that  :yesnod:
Brass
I agree with Tan Top - check the filler neck vent tube.  Mine was venting into the trunk instead of exiting through into the frame rail.  :eek2:  There was also a missing body plug.  After fixing those two things (and with no exhaust leaks) the fumes are GONE - even though the car still seems rich at idle.
SRT-440
Some of it may just be the nature of the beast...My Grand National is fuel injected and smells of fuel bad and it's cuz there is no cat on the exhaust...if I replaced it most of it would go away.
Check again for exhaust leaks
"It's not the size of the dog in the fight, it's the size of the fight in the dog..."
2012 SRT8 392 Challenger (SOLD)
2004 Dodge Stage 1 SRT-4 (SOLD)
1970 Plymouth Road Runner Clone w/6.1 HEMI (SOLD)
1971 Dodge Dart w/440 (SOLD)
1985 Buick Grand National w/'87 swap and big turbo (SOLD)
Thats cologne to me....wife & kids say I stink bad after a ride in the car.....I beg to differ....  :Twocents:
:drive:
Cooter
What's gonna suck Dino is, Even after you install this high dollar EFI system, and you still smell fuel.
It's a 1969 Charger..........Not sealed up as well as a 2012 Charger. No cats, No EVAP system, Etc. Course, this one isn't as cool...
Back N Black
I have a Holley 770 Carb. i don't get any fuel smell, well a little on start up.
red69superbee
my 69 coronet always made me smell like exhaust,seemed to get worse as time went on and seals got older.But old cars smell gassy and new ones will to if the catalytic converters arent there.I always had the tailpipes go out straight with tips, but changed to pipes that turn down under the bumper, and that took away about half the fumes i would smelll going down the road
greenpigs
rich mixture
fuel leak somewhere
I would try the above as most of it is free to do & not a bad idea just to make sure it is all working properly.
1969 Charger RT
Living Chevy free
XH29N0G
Same as what the other guys wrote.
The smell always brings back memories of childhood.  For my car it can be intensified or lessened with jetting and carburetor adjustments, but has never completely gone away.  If it is different than before, than something must have changed.  Otherwise, it might just be the nature of the car.
Or maybe it protects us.
Cologne eh?   :smilielol:
Thanks for all the comments guys.  I know it may be hard to get rid of all the smell but I'll go through everything listed here to reduce the issue as best as possible.  Now I had no idea about the cats...so what if I install cats?  Is that even possible on these things?  Will it ruin the wonderful music coming out the back?
I thought about losing the exhaust tips but I'm a bit hesitant, I like the stock tips a lot.  I'll try everything else before I do that but I may have to bite the bullet.
bill440rt
Quote from: Just 6T9 CHGR on February 14, 2013, 05:29:34 PM
:drive:
LOL
Me too!  :rofl:
I try not to leave to door open too long from the garage into the house so the smell doesn't come inside. They HATE that.  :slap:
Quote from: bill440rt on February 15, 2013, 08:03:19 AM
:drive:
LOL
Me too!  :rofl:
me three  :yesnod: although don't smell inside the car or even if windows open , but if idling away at a stop or in traffic etc & the wind is blowing a certain way , can smell it with windows down ,  :yesnod:
been thinking what year is your thermoquad , only some not all have a esc vapour breather tube ! if not connected up , will have raw gas fumes worse then engine is hot ,
Quote from: tan top on February 15, 2013, 09:43:20 AM
:drive:
LOL
Me too!  :rofl:
The TQ is a mid 70's but it's not on the car yet.  Currently has an Edelbrock 1407.  The TQ doesn't have that breather tube though.
super77se
Quote from: Dino on February 15, 2013, 09:51:38 AM
i knew i missed something lol , the bowl vent on a carb that isnt connected will allow fumes out as well.
i run a 1406 on my duster and after running it , then shutting it off when its hot outside, i get the infamous fuel percolation and can smell gas from outside the car ,but i never smell it on the inside. i also removed the charcoal canister and the tank vent line will seep fumes from time to time.
I used to have the boiling fus well, real bad.  Since installing the felpro gasket with crossover block that problem was taken care off.  Funny enough the smell is not so bad under the hood but it's bad standing next to the car and pretty much lethal standing behind it.
I will make sure that the firewall and its seals are fixed and the exhaust itself is leak free but would it be overkill to replace the  entire fuel system?  I don't seem to have any fuel leaks and the car runs fine but it is pretty old.  At the minimun I will replace the fuel lines but maybe I should just replace the tank and sender while I'm at it.
super77se
at the very least i would crawl under there and inspect the rubber line from the sender to the hard line. i would also check out the rubber from the tank line to the fuel pump. they get soft and mushy over the years. im not going to say you should replace the hard line unless you are pulling brown fuel from the tank. i had a super nasty tank full of rust. i only replaced the tank and to this day im using the hard line. definitely check all your body plugs while you are under there, there are a lot of them.
Cooter
Quote from: Dino on February 15, 2013, 07:45:38 AM
Catalytic Converters on CARB'd engines is a big no-no. Mainly because of the tune-up...Carb's dump fuel in the engine. ALOT of fuel= BAD for Cats.
Will burn 'em up within a few thousand miles. EFI? Only if the tune up is of a Stock type set up for fuel economy. A HUGE fuel curve will do the same thing even with that Electronic carb sitting on your intake. Afterall, the ZDDP you use in your "Oil burning" (by today's standards), 440 or whatever will KILL those cats.
Blusmbl
I think you're smelling fuel from the carb.  I've never had my Mopars do it, but my '66 Pontiac reeks of fuel after running it at WOT for 5-10 seconds.  The smell is definitely not coming from the exhaust, it's originating from the engine compartment.  Check what others have mentioned... float level, mixture, etc.
Caintmakit Racing: Craptastic!
-66 BondoVille Roadster
-05 QC Hemi Ram
-looking for another '68-'69 Charger
