wiring harness for Hideaway headlights
Started by randy73, January 30, 2013, 03:40:15 PM
randy73
I bought the hideaway headlight harness, but it is a little less than 4 ft long, this is the wiring that plugs into the motor, is there another piece of the harness that goes through the firewall to the relay?
Mopar Nut
What you have is called "Forward light harness". There is another harness that plugs into the firewall. That one plugs into the Forward light harness next to the battery.
green69rt
Quote from: Mopar Nut on January 30, 2013, 06:38:29 PM
Take a little care to protect the plug because it is close to the battery and the fumes tend to corrode the metal in the plug.  (Happened to me.)
Quote from: randy73 on January 30, 2013, 03:40:15 PM
it consist in 3 sections. I was to explain it, but better check this:
http://www.ebay.com/itm/1971-72-73-74-Dodge-Charger-concealed-headlight-complete-wiring-conversion-kit-/390455905373?pt=Vintage_Car_Truck_Parts_Accessories&hash=item5ae8fc4c5d&vxp=mtr
IT CAN BE HOME MADE EASILLY... however if just a section is needed and you don't want to make it by yourself, the guy sells these separatelly ( check their auctions ). I think he is Jimmy Boros
here is how the wires must run
http://www.dodgecharger.com/forum/index.php/topic,62488.0.html
