alignment cams
Started by flyinlow, January 02, 2013, 09:37:33 PM
flyinlow
OK the moog offset bushings are installed arrows out on the front ones and arrows in on the rear ones and we are ready to put the UCA's back on the car. We have new Moog cam bolts, dose it make any differrence what position you put the cams in? I was going to put all the cam offset at 12 o'clock , the bolts being at their highest position and then take it to the alighnment shop next snow free day.
charger Downunder
Put them both in at the same position level the front out take for a quick back and forth to settle the suspension down, drive back to a level surface measure from floor to bottom lip of wheel arch on or four wheels to check height adjust height if needed take the weight of the front by jacking up the car to adjust torsion bar height bolt,once all at a height your happy with. Stand at front of car and look at the wheels to see if top needs to go in or out adjust top cam bolt. This should get it good enough to drive for an alignment.
[/quote]
