Answer the question with a question
Started by JB400, December 09, 2012, 03:04:23 AM
polywideblock
which are we measuring depth or width ?
  and 71 GA4  383 magnum  SE
Shouldn't we measure the height as well?
polywideblock
how do you measure the height of a hole ?
polywideblock
isn't that the height above the ground of the hole not the height of the hole itself ?   :icon_smile_big:
Which part of the hole are you measuring?
polywideblock
is it to the top or to the middle ?
Don't we need the shape of the hole in question to determine how to measure it??
polywideblock
polywideblock
isn't half a hole just a small hole ?  :scratchchin:
Would that make it a whole hole then?
polywideblock
polywideblock
if there is no hole its whole isn't it ?
polywideblock
polywideblock
is it a wall between dimensions  ?  :scratchchin:
polywideblock
everything's a theory until someone does it isn't it ?
polywideblock
Would you believe I have?  I do it while the building is being built and there is no sheetrock on the walls :yesnod:
polywideblock
the real trick would be to do it with the sheetrock wouldn't it ?
