1968 Dodge Charger Fuel Tank Restoration
Started by RIDGERACER383, November 14, 2012, 04:42:23 PM
RIDGERACER383
Hey Guys.Been tossing the idea around about fixing up my fuel tank instead of buying a new one.I looked into sealing it but I heard that with ethanol in the fuel now it will break down the sealant and it will start peeling out and get in your system.Now this was just one product with the reviews I read.I'm sure there some really good ones out there.
I'll update this thread as I go.
The first thing I did is soak the hanger bolts with croil.There pretty rusty so i'll go out tonight and soak them one more time and they should come off tomorrow.
The end of the hanger bolts are up against the tank so I hope I can get it to move so I can get a deep well socket on it.
On top of the fuel sending unit I unhooked the wire for the fuel tank gauge which pops right off.The rubber fuel line which connects the two metal lines has some fuel line clips which are hard to remove.I'm going to cut the rubber line since it needs replaced anyway and use regular hose clamps.
Also connected to the rubber line is a metal brace which I guess is factory.
So thats where i'm at now.I'll post more tomorrow with the tank out.If you want anymore pics just let me know and i'll do my best to take them.
1968 Dodge Charger 383 4bbl / 8.75 Rear 3.55
Cooter
FWIW, NEVER....Repeat, NEVER try and repair a fuel tank when new ones are available...You are asking for heartache.
bill440rt
With all the time, labor, & materials it takes to fix up an old tank you'd be well ahead of the game by replacing everything. All of that stuff is available new & is relatively inexpensive.
Most repro tanks come with new gaskets & a new lock ring. Repro sending units can be found inexpensively on RockAuto, or check eBay. Those two items will be your biggest expense.
Same with the straps & j-bolts, they are not that expensive.
That "metal brace" is a ground strap. Get a new one (they are cheap), to ensure a good ground.
Lastly, I try to avoid worm clamps on fuel lines whenever possible. The serrations have tendency to cut into the rubber fuel line (not good), that's why the factory used those crimp style clamps. Most auto parts stores have them. There is a special tool out there to crimp them, however I've found that a pair of nips wrapped with some tape or a rag works just as well.
HeavyFuel
This is a good tank:
Fuel Tank 1968 Dodge Charger R/T 8 Cyl 7.2L
Spectra Fuel Tank Charger
Spectra Price: $ 195.81
Part #: SPICR9A
While we're on the subject, any good Charger only fuel cells available.  I'd rather have one in the stock location then have one mounted in the trunk.
squeakfinder
  I've tried fixing up fuel tanks. It is a complete waist of time. It will leave you stranded with a plugged fuel filter or worse, a screwed up carb. Thank's for sharing those pic's. Looks like that ground strap went down with the Titanic.
67_Dodge_Charger
I repaired my gas tank for my 67 Charger and I can tell you I wish I had looked harder at a replacement.  They say that hindsight is 20/20 and I can see that I need to replace gaskets, fuel tank sending unit and fuel lines (maybe gas tank clamps) still with the price of repair $150 at a radiator shop.  How much will it cost to get a brand new replacement tank? Plus you don't have to worry about stuff floating around plugging your fuel line and fuel filters.
Good luck Robert :popcrn:
RIDGERACER383
Thanks for the replies guys...I was at the salvage yard all day and didn't get a chance to work on the tank.The tank in my car is in good shape on the outside except where I dented it and it has a small leak which i'm going to braze and solder.As for inside the tank i'll post before and after pics and show how I did it.It should be super clean when i'm done.
XH29N0G
When I was a kid, we had someone at the place where I worked try to weld or braze a full fuel tank.
Luckily he was caught beforehand.  Please be careful.  I am sure you have thought this through, but things can go wrong.
The guy I knew at work was not stable and ended up being picked up later for several murders.
Or maybe it protects us.
RIDGERACER383
The way you secure a tank so you can apply heat is to run a hose from the tail pipe of a running car into the tank for about 10 minutes...then your good to go.
bill440rt
Quanta Products
1-800-235-8788
www.gastanks.com
It doesn't get any more headache-free than that.
Why would you even consider repairing a dented tank with holes in it??  :shruggy:
RIDGERACER383
The tank is solid..the tank hit a rock in my yard and dented it and put a pinhole in it.I figure why buy a tank when I can use some elbow grease and have a good original tank.I'm going to pop the dent out from the inside before I repair the pinhole.
FLG
Your wasting your time trying to save a 40 year old fuel tank. Ditch it and buy a new one. There is no reason to save it and your looking for headaches down the road.
Buy a new tank, new sender, new hoses, new j bolts, new straps, new ground strap, and be done with it.
When it came time to remove my tank i emptied it, cut the j bolts, and threw the whole thing in the trash. Mind you the tank didnt leak, everything worked fine....but its simply not worth it. Im spending thousands restoring my car, why bother keeping a rusted, filthy tank?
Were not talking an og tank on superbird an original superbird or something super rare where something like that would/could make a difference.
Also they sell the style clamps Bill is talking about with a bolt thru setup, much better than worm clamps and looks cleaner.
RIDGERACER383
I like those clamps.Really clean looking..I don't have the cash to fork out for a new tank so that's why I'm restoring this one..The inside of the tank will be rust free when I'm finished.
ACUDANUT
Good luck. A 43 year old gas tank repair ?  Time to say bye bye.  if you cannot afford a new gas tank, please sell your car to me. :icon_smile_big:
RIDGERACER383
I got the tank out today and have to say i'm really surprised.The tank is solid with only surface rust on the top where the mat is at.The straps are in great shape too along with the hangers.
Heres a picture with the mat removed...You can see the surface rust.
I looked inside the tank with a flash light and the bottom is nice and clean.There is some stuff in the bottom of the tank and the gas stinks.
Theres a few places in my trunk that needs patched but mostly solid.They apparently undercoated  these things with the tank in.
The only place i'm stuck at now is i'm not sure which way the sending unit lock turns to get it out.I'm sure its counter clock wise.I tried getting it out with the hammer and screwdriver but it didn't budge,so I have it soaking in croil.
I'll get some more pics up tomorrow when I start cleaning this thing out.
After seeing your tank,  I'm with everyone else.  Besides, no idea how much crud is at the bottom of the tank.  I hope your replacing your lines.  Otherwise, you'll be changing fuel filters every week.
RIDGERACER383
I'm going to buy some line and make a new fuel line for it after I get the tank finished.
bill440rt
Invest in one of these:
http://www.ebay.com/itm/Mopar-Ford-Mercury-Lincoln-gas-fuel-sending-unit-tool-/400327135781?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d355b5225&vxp=mtr
Oh yeah, the ring turns COUNTER-CLOCKWISE to remove it.
After you get done restoring that tank & cleaning out the inside, let us know down the road when the rot eats another hole in it. You'll be spending double then doing this work all over again.
Best of luck to you.
RIDGERACER383
Thanks for telling me about the ring..Now I don't have to fight it both ways.As for the tank it has no rust holes just surface rust.The hole was made when I was moving it from my back yard and I went over a rock and it put a dent and a pinhole in it.
Lennard
 :rotz: I can't look in your wallet but be smart and safe up some $$ in the next few month and buy yourself a new tank. The people giving you advise here are not new to the game.
My gas tank was in better shape than yours and I tossed it and bought a new Spectra tank, do it once... do it right.
HeavyFuel
Dispite everyone's urging to get a new tank........he continues to march on with the intention of trying in vain to save one that's obviously gone. :shruggy:
Rookies.    :rotz:
This thread should be considered closed.
Mine looks in a lot better shape than the one he has, and I doubt that I'll reuse it.  40+ years of crud and rust in a tank feeding a rebuilt engine of x amount of dollars, heck, I might as well just burn the money and stay warm.
ACUDANUT
I doubt that lock ring will even come off, without some of the gas tank with it.  Spectra time.
RIDGERACER383
The tank is nice and clean inside with just just a few dirty spots in it.I'm having trouble getting the lock ring off.I guess its seized.I'm trying to get it off clockwise.The sending unit isn't rusted and looks pretty good for being over 40 years old.I'll get that ring off hopefully.
