Inner rear window corner supports? 68 Charger
Started by JThotrodjunkie, October 24, 2012, 10:56:58 PM
JThotrodjunkie
Looking to see if anyone reproduces the lower inner window corner supports for the charger yet.  These are welded in at the left and right side of the car, they are attached to the package tray and the inner skeleton also are formed to support the lower windo frame under the dutchman and the quarters, I will post pics but I am sure many have this problem.
WAR is often caused by clashes between religions, religion is now a capitalist market, forget all of it.  Take 15-20 min out of the day and look around at the world and be thankful we are on this planet, warmed by a star, because in the end all you get is a dirt nap!
cdr
JThotrodjunkie
Wish someone made them, guess I have to fabricate.  I think I might make them like 3/16 and solder or braze a barb fitting for a drain! Hahaha!
yep I gotta be crazy.
charger_fan_4ever
My car had the optional no rear inner window frame too.
This had to be fabricated
Other side was nasty too here it was after a rebuild.
JThotrodjunkie
sweet work man! I never seen a repair that nice!
