73 sway bar links
Started by ralley72, October 16, 2012, 02:29:57 PM
ralley72
Hey guys,
I need to replace the front and rear sway bar links on my 73 RR, they are factory. I talked with Firmfeel, but they don't carry the factory replacements. anyone know where to find these links?  I did a search on here and came up with nothing.
Thanks,
Mike
1973 Roadrunner 400 mag. 4 sp
there are some right now on ebay.
I have couple NOS too, but overseas.
Rears are not available HOWEVER I think front kind will work as replacements
Iron Chef
Unless you are doing a "down to the last detail" restoration, I'd consider going aftermarket.  The bars that are available now are so far superior in size and strength to what came stock on your '73.  I have a Hellwig bar on the rear of my '71 and I can't tell you what a huge difference it made.
Just my  :Twocents:
:cheers:
Most of your life should be "off the record."
Stretch
I rebuilt my end links. I replaced the bushings by drilling out the spot welds then re welding them when I was done. I don't recall who I got the bushiing kit from though. I'll look and see if I have that info in my records some where. I want to say I got them from the same place I got my spring isolators and shackle kits from. I did the K frame bushings and front bar at the same time. I think I got all of the parts from the same company at the same time.
I may be schizophrenic but at least I have us!
