Tire Paint
Started by plum500, October 03, 2012, 03:59:00 PM
plum500
Anyone (probably on other projects) have any experience with the Gledi white wall tire paint? Looking at the demonstration video - it looks like incredibly tough stuff. I have a 17" on my car, and while I thought I'd be OK with the black wall tires, it's just not doing it for me, and I want the letters white, so I'm wondering if this stuff will do the trick. (tires are 275/50/17 out back and 255/50/17 in front - so there's some sidewall)
In this day in age where you can sell advertising space anywhere, I am surprised RWL went the way of the dodo.
plum500
oldcarnut
plum500
Actually... I tried something else out tonight, and posted, then deleted because I thought it didn't work. Turns out, I just had to let it dry for a couple hours. What I did was dry to the touch, but I think the enamel I used reacted with the paint I used as a primer, and things had cure a bit.
If anyone is curious, either for doing up raised letters on 17s, or whatever, maybe repairs or applications on other types of projects, I found this worked:
* Scotchbrite pad on the rubber you want to paint, I criss crossed a bit, but it doesn't actually do anything to the tire that you are going to feel with your finger, just makes it nice and dull
* Degrease - I used a piece of paper towel dampened with a bit of lighter fluid to clean my test piece of rubber
* Used Dupli-Color vinyl fabric paint as a base coat (if any paint has got to be flexible, this is it) and lightly sprayed an even coat on the test
* Followed up the vinyl/fabric paint with a top coat - I just grabbed a can of yellow enamel I had sitting on the shelf
I used a 3/8" thick slab of rubber to test on, and I can fold it in half, scrape at it, and the stuff will not come off.
I read about someone using the Dupli-Color vinyl paint, on another forum - but I wanted to check it out, and improve on the prep method. As well, the colors available are limited for sure, and the white isn't all that great, so I thought why not use it as a base coat? Chances are, another paint will still to it - plus that opens the door to either white or yellow lettering.
And with the spray, vs the thick brush on stuff, I think I can make this pretty convincing with sharp edges, and no brush strokes.
Fred
Mopar Nut
Quote from: plum500 on October 13, 2012, 11:01:15 PM
Fred
Any pictures?
plum500
I didn't have a chance today. Will post pics in the next couple days though. Final thing I want to figure out - because I am spraying, masking with tape would be a pain and probably not that effective anyway. Though I think some tuck tape would stick pretty well, outlining letters would take way too long. So I am either going to try some liquid stuff - or I think what I will probably try first is a water soluable gel. Should be able to brush it on around the raised letters I am going to paint (and mask a block around the word as close as possible with tape) and shoot it. Hopefully it will give a nice crisp line and just wash off with the hose. I've seen some pics posted on other forums of brushed jobs - there's some really good, and some really bad. If I can't make someone look at least twice and have to ask me where I got the Nittos with the raised yellow lettering, I don't want to do it :)
Here's one of the more successful hand painted jobs I've seen - but, this took some time and patience I'm sure, and a steady hand that I just don't have very often.
http://sandscorcher-eng.blogspot.ca/2010/03/tire-porn-2.html
Patronus
Huh.. :scratchchin:
thanks for posting
'73 Cuda 340 5spd RMS
'69 Charger 383 "Luci"
'08 CRF 450r
'12.5 450SX FE
Mopar Nut
Could you use carbon paper to trace the letters, then transfer the image to wide tape. Tape the cut out lettering on the tire over the original lettering. Then paint.
plum500
That's a great link - masking like that seems like it would not be that bad.
I actually thought about that carbon paper idea last night ... well, sort of, I was trying to think of a way to do a rubbing to get a print of the lettering.
What I was thinking though - if I could get a print of the lettering, I would have the letters cut in rubber, and then just glue them on with a good rubber cement. (A *very* thin rubber with a decent rubber cement, I expect would outlast the tire)
There's a company that does this - but their website is a little limited - no information on what brands/model tires they will do. I just sent them an email.
They are a bit pricey though.
For the 10 bucks I paid for the vinyl paint, and a little time investment, I still think I'll paint. I might check out that paint in that link above too though.
Mopar Nut
