edelbrock head and headman header
Started by lasvegas69charg, October 03, 2012, 09:24:54 AM
lasvegas69charg
hi. Is there anyone running the edelbrock rpm head and headman 17/8" header on a 383? It seems that the #6 spark plug is to close to the header and can't get the spark plug wire on without touching the header. I tried to dimple it but not enough room with the hammer to get the right dimple. Any suggestions?
69 dodge charger 383/727/3.55 (my dad is the original owner-matching number) stroked to a 496😉
What wires are you using ? Straight boot or 90* ?  The angled plugs make wire routing/fitment a headache with some headers.  :P
Can you post a pic ?  :scope:
lasvegas69charg
471_Magnum
I generally like 135 degree boots for header applications.
You're going to need a kevlar sleeve on that one... and a bigger dimple.
justcruisin
Best bet would be to mark it then pull the header off and get some heat on it to make a nicer indentation. If it is too close it is only going to give you grief.
That is tight....as mentioned above, you will need more clearance  :yesnod:
Best way to do this is to remove the header and heat up the tube (with a torch) where you want to clearance it. Get the tube nice and hot and lay a socket on the tube and hit the socket with a hammer. I like to use the side of a 3/4in deep impact socket to make a nice radiused dimple.  :smash:
lasvegas69charg
alright I will give it a try. The funny thing is that everything else fit perfect
flyinlow
Accel makes a shorter plug. Not much shorter , but with an angled boot it might work. About 3/16 " shorter.
