tie rod ends
Started by Nacho-RT74, September 21, 2012, 01:24:17 PM
when you get MOOG-ES401L and MOOG-ES401R ( or whatever brand, Raybestos, Mevotech, TRW etc...  ) are you getting all 4 pieces in those 2 PNs, one each ? or do I need to get 2 of each, being 2 L and 2 R ?
cdr
1 each in the box,also get new sleeves
sleeves are perfect on my car, don't need them
so would need to get 2 L and 2 R
cdr
375instroke
The thicker ones, like for a '74 Newport, are stronger, the same length, and half the price.
then will require to get a new sleeve too. If my car has survived perfect to the BAD local streets conditions being a driver with the originals tie rods ends sizes, I don't see a reason to get a bigger " stronger" assembly ;)
375instroke
The sleeves are cheap, and it's half the price.
Moog 9/16" tie rod ends are $40.79
Sleeves are $12.80
Moog 11/16" tie rod ends are $15.50
Sleeves are $13.48
$163.16 total for just 9/16" tie rod ends
$88.96 total for 11/16" tie rods and sleeves
These are Rock Auto prices for a '69 Charger and '74 Newport.
eeeehm, rockauto has the  9/16" tie rod ends in $11 each
375instroke
Sorry.  I looked up ES319L & R for a '69 Charger, which was my application.  What changed in '70 to warrant a new part number?  I would have thought '69 and '70 would be the same part.
