looking for pics
Started by Brightyellow69rtse, September 06, 2012, 08:36:07 PM
Brightyellow69rtse
anyone have any pics of the front end suspension? i just want something as a reference so i can make sure mines all correct.
Back N Black
a few good pics in this link.  :2thumbs:
http://www.dodgecharger.com/forum/index.php/topic,79862.0.html
another: http://www.dodgecharger.com/forum/index.php/topic,32597.0.html
and torque specs.
Ball Joint to Control Arm (Upper) 125 FT/LB
Ball Joint Stud Nut (Upper) 100 FT/LB (Lower) 100 FT/LB
Rebound Bumper (All) 200 in/lbs.
Adjusting Bolt (Upper Control Arm) 65  FT/LB
Pivot Shaft (Lower Arm) 145 FT/LB
Steering Knuckle Bolts (Upper) 55 FT/LB (Lower) 160 FT/LB
Strut to Lower Control Arm 105 FT/LB
Strut to Frame 52 FT/LB
Sway Bar Link Nut 100 in/lbs.
Sway Bar to Frame 200 in/lbs.
Sway Bar Plate to Cross Member 30 FT/LB
Idler Arm 65 FT/LB
Tie Rod End 40 FT/LB
Tie Rod Sleeve Clamps 132 in/lbs.
Shock (Upper) 25 (Lower) 50
