Distributor retard
Started by flyinlow, August 30, 2012, 01:26:47 PM
flyinlow
Where any Mopar distributors equipped with an electric retard as part of the vacuum advance?
Having hot start issues with a 440 when I increased the base timing.
Never heard ofany type of retard in the vacuum cannister  :scratchchin:
What starter are you using Craig ? Stock or mini ?
I think I saw that part listed on eBay in the past, something like 71 6 bbl only?  :scratchchin:
flyinlow
Quote from: firefighter3931 on August 31, 2012, 09:56:04 PM
Son's car 9.5 cr (we think) iron heads . Old style starter. A mini would be a good idea. Even have a used one sitting around,but I don't want to mess with his old headers until the driving season is over.
cdr
sounds like you have a dist problem,what is the initial & total timing set at
flyinlow
  I tried 15* BTDC but hot starts where a problem.  Starts Ok with 10* , but then not enough total.  Put faster springs in starts advancing about 1500rpm and all in at about 2500 rpm.  Distributor was rusty and gunked up and the vacuum advance leaked badly.
Not sure my dial back timming light is working right.   It doesn't work right on my MSD equipted car , but this car has a stock Mopar electronic ignition. Need to clean up and mark the dampner with 30* and 40* marks
74bluecharger440
i'm haveing the same hot start problem with my 440 . also MSD ignition, i've tried lots of things, but pretty sure the  timeing is the problem now, I will follow this thread to get  advice ..Thanks .
cdr
if it just spins slow probably not timing,but if it spins fast then slow,fast slow,like rump rump rump rump thats a timing issue
shorty442
pretty.sure.way.back.when.,.....my.buddy's.'70.440.4spd.had.an.elect.retard.for.starting.purposes---likely.due.to.being.a.California.car;...smog,. emissions,etc..
nvrbdn
70 Dodge Charger 500
70 Duster (Moulin Rouge)
73 Challenger
50 Dodge Pilot House
flyinlow
Has trouble cranking after a 10 minute stop. Pull the coil wire and it cranks OK. Retard the timing and it starts when warm. I have a mini starter on my 440 and run 24* BTDC at idle and it starts fine warm. Different build with aluminum heads.
Quote from: 74bluecharger440 on September 01, 2012, 04:16:42 PM
MSD just makes some dial back timing lights act funny. Their ignitions boxes are fine. They actually make boxes that retard the timing during cranking.
Quote from: shorty442 on September 01, 2012, 05:43:07 PM
Thanks, I will do some looking.
Quote from: flyinlow on September 01, 2012, 12:15:04 PM
Install the mini starter and your problems will be over. I have one on the 572 with the timing locked out at 35* and that little badboy spins the motor over like nobody's business  :scratchchin:
