What have you done with your Charger lately?
Started by XS29L9Bxxxxxx, August 19, 2012, 10:51:52 AM
BrianShaughnessy
I put 80 mil some ebay brand of sound deadener in the roof of Sinnamon today..
cdr
be sure & cover the silver with something or you will see sparkling stars through the little holes in the headliner.   :Twocents:
beautiful Charger !!!!
71charger_fan
Updated the headlamp door Dodge badge.
nvrbdn
Quote from: BrianShaughnessy on January 20, 2016, 09:56:17 PM
  Love that color. :drool5:
70 Dodge Charger 500
70 Duster (Moulin Rouge)
73 Challenger
50 Dodge Pilot House
myk
Took it out for the first time in weeks because of the near-constant rains, only to be nearly rear ended by someone in an Alero who wasn't paying attention.  Why do I even bother leaving my house, ever?   Anyway I burned my wallet and a tank of gas just running errands.  I even got a thank-you note from Saudi Arabia for my efforts...
fy469rtse
fu%$ much damage Myk,
put a third eye level brake light in it , modern $%ucking useless drivers are trained by laziness to eye watch that  :2thumbs:
sorry mate its a must
myk
Quote from: fy469rtse on January 22, 2016, 12:48:39 AM
Thats not a bad idea.  I'll definitely look into that
69bronzeT5
Love love love it!
WhiteOnGreen
Put a restored woodgrain wheel custom made
UH60L
November:
Wired all of the dash except headlight switch connector and radio
Installed alternator (loosely)
Two weeks ago:
Wired taillights, backup lights and license plate light
Fixed rear bumper mount on right side (support welded in too high, filed down both holes for proper alignment)
Installed rear bumper (loosely)
Today:
Installed speedometer gear and connected cable
Installed flex plate to torque converter bolts
Torqued balancer to crank bolt
Installed crank pulley
Installed fan and fan pulley
Installed belt
Installed missing engine to tranny bolts
Installed engine dipstick
Installed transmission dipstick
Installed starter relay
Wired and connected neutral start switch plug/harness
Installed shifter linkage between steering column and bellcrank
its been a good day!  :cheers:
grdprx
Busy man UH60L !
I replaced the cheap chrome dipstick with a milodon flexible steel dipstick.  The chrome one was blocking the hole on the steering box for the fitting that is supposed to go there.
Also put the radiator back in, Champion replaced the one that was leaking.
That and a water heater replacement, it was a productive weekend.
myk
grdprx
Quote from: myk on January 25, 2016, 07:24:56 AM
Flexible dip stick?
Yup, it has a braided steel tube.
ODZKing
Quote from: grdprx on January 25, 2016, 11:20:46 AM
Flexible dip stick?
Oh, I like that.  Where did you find such an item?
The one I see at Jegs is Chebby only.  And summit doesn't specify.
How can you be sure you are getting a correct reading?   :popcrn:
grdprx
Funny story, I got it from a friend who had ordered one many years back.  Company sent him 2, and didn't want the extra back; wasn't worth return shipping.  This one was for a 440 and I think some Fords also, I'd have to check the package.
On the oil level reading, I confirmed I was full prior to removing the old dipstick; then installed the new one and made a mark with a pair of dikes.
Quote from: WhiteOnGreen on January 24, 2016, 04:43:16 PM
That is sweet!  Details?  Real wood?  Thickness?
polywideblock
                              common now that's just bragging  ;)
  and 71 GA4  383 magnum  SE
CDN72SE
After 24 years dropped the car off for body & paint. :icon_smile_big:
Safe and sound  :2thumbs:
1972 Charger SE
EccentricMagpies
'74 Rallye 4spd (WH23L4) (1 of 94)
'74 Rallye Auto (WH23L4) (quad black)
'69 Swinger 340 - 4spd
'70 Duster 340 - 4spd
stripedelete
2592 creston
   Put some non ethanol gas in it and let it run a bit
myk
Lamented about the rainy weather and all of the car meets that we're missing as a result...
cavemanno1
Bought a lot of parts for it!PST suspension rebuild kit,wirering,Fire core electronic ignition,complete interior part from upper door pads,frame connectors,mirrors,wheel well trim moldings,bigger front and rear sway bars,1.03 torsion bars,11.75" slotted and drilled front disc brake set up,AMD sheetmetal,gas tank,steering wheel,PS pulleys and a lot more.Finally got new wheels and tires!
Thanks to tantop and everyone else for their help and Bull for his wheels and tire combo!These 295/50/15 look great under the car.Fills up really well the wheel well  :drool5:
EccentricMagpies
Quote from: ACUDANUT on January 27, 2016, 03:00:45 PM
Quote from: EccentricMagpies on January 26, 2016, 01:18:52 PM
What is the color going on ?
what color are you thinking?
What color am I thinking?
Well... If you are asking me to guess I'll go with some sort of blue since his thread on his car mentions several blue colors
Maybe you know?
