Axle bearing replacement
Started by randy73, August 11, 2012, 07:34:48 PM
randy73
Is it possible to replace the axle bearings myself or do I need a shop?
73 charger 8.75
Looks like there is a retaining collar and maybe the bearings are pressed on?
471_Magnum
Bearings generally require a press.
you can get the old ones off by cutting groove in the retainer & bearing race & splitting them with a chisel but you still need a press to seat the new parts
471_Magnum
I've actually heated up carrier and pinion bearings up to about 450 in a toaster oven and been able to drop them on. Never tried it with the outer axle bearings though.
Note, if you try the heating method, DO NOT PACK THEM WITH GREASE FIRST. Also, probably a good idea to wait and try in when your wife isn't around.
bakerhillpins
Quote from: 471_Magnum on August 12, 2012, 09:12:56 PM
Common practice to put motorcycle wheel bearings in the freezer so that they will drop into the hub without a press. Can't see why the reverse wouldn't work.
One great wife (Life is good)
96' VFR750 (Sweet)
Capt. Lyme Vol. Fire
