360 Magnum stroker
Started by 694spdRT, February 04, 2006, 11:13:28 AM
694spdRT
I did a little searching on this type of build up but, I didn't find much on factory rod and piston combinations. Can the factory rods or pistons be used with the stroker crank or must you use aftermarket? I have a 360 Magnum and thought it seemed like a possibility if it doesn't cost a fortune. Otherwise I may just build it with the standard crank. Also, for a street driven car is there much to be gained by going with the Mopar R/T magnum iron heads over the standard production heads I already have?
1968 Charger 383 auto
1969 Charger R/T 440 4 speed
1970 Charger 500 440 auto
1972 Challenger 318
1978 Ramcharger 360 auto
golden73
I believe you can use the stock rods for the stroker... they would be the same length as the aftermarket ones. You would need new pistons for sure.
694spdRT
I wonder what pistons the new stoker crate engine uses? Should be a part available through any Mopar dealer.  :scratchchin:
I think they are a cast aluminum piston. If I were to build an engine forged would be better anyway.
1972 Challenger 318
Beer
I built a smallblock stroker from my 318, 4" Bore 4" Stroke for a 402 cu/in engine, all Forged.
Thread here if your interested, list part numbers and machining cost in the thread, as well as issues I encountered.
DAIL UP BEWARE.
http://www.dodgecharger.com/forum/index.php/topic,283.0.html
If I remember right rod length was 6.123"
Cheers
Beer
1973 Dodge Charger 402 Stroker Smallblock 414 HP/ 466 ft/lbs torque,  8 3/4" 3.91 Suregrip rear w/ DR. Diff disk brake conversion, CalTracs single leaf and Rear Suspension, VFN Bulge Hood, Running, needs interior completed, Had to give to Ex-Wife in divorce 2017...
stock rods are 6.123 if you want to maintain rod ratio you  can use a longer rod & even shorter piston
Rocky
As a general rule, even the stock rods offer a great ratio compared to the other brands out there.  There are several different pistons available debending on your engine combo, but few differ from the 6.123 rod.
decide on a piston, and contact the manufacturer
694spdRT
1972 Challenger 318
