SB Magnum Heads
Started by 1BAD68, August 07, 2012, 08:23:57 AM
1BAD68
Friend of mine found a set of low mileage magnum heads from a 90something Dakota. I want to swap these onto my stroked 318 but heard that they are known for having cracks.
Where do I look to see if they are cracked? I'll have them magnafluxed later but am wondering if visually you can see any cracks?
1BAD68
Is this where they typically crack?
Cooter
Yikes! I better have mine on my 360 checked before I work 'em then.
Yes, I believe that's the common crack. It's debatable whether it's truly an issue though as many fine running engines were found to have cracked heads. I have a 30k mile 2002 that I have a set of aluminum heads for. One of these days I'll yank the stock heads and see if the cracks exist.
That is the normal place to crack , you can drill the crack & install a plug & remachine & you would never know it was fixed , we have used many cracked 302 & 308 castings .
