Speedo gear question
Started by randy73, July 28, 2012, 09:13:56 PM
randy73
I am putting in a 46rh into my 73, PATC sent me a 32 tooth speedo gear, but the gear is smaller than my 31 tooth and won't work. So, if I stick with my 31 tooth and I have 15" tires, how much will that throw my speedometer off?
randy73
Why I should not work on the car when I am tired, woke up and looked at the housing and realized it was adjustable, so the 32 tooth gear works.  :brickwall:  :brickwall:
Glad you figured it out! I was stumped the first time I looked at one too.
You need to know your tire size and rear gear ratio to determine what tooth pinion you need
randy73
Quote from: c00nhunterjoe on July 29, 2012, 11:36:52 AM
I already did, thanks. That is why I am going to 32, from 31.
PS: If anybody needs a new log shaft 31 tooth, I have one.  :icon_smile_big:
oldkimmer
.........I'm a thinking u need a few more teeth than that, unless it was out the other way b 4 .......kim....
Back in the good old days 1968 charger rt 440 magnum . 1968  charger 383 magnum. The Beast has been Unleashed!!!!!!!!!!!!!!
