Alcohol carb conversion ??
Started by Highbanked Hauler, July 14, 2012, 05:36:51 PM
Highbanked Hauler
 Is it better to get a carb. already set up for  E-85  or get alcohol parts,if you can, to convert one over ??
92 Cummins Turbo Diesel
04 PT Cruiser
cdr
send your carb to c&s they will make it work :Twocents:
alcohol need about 40% more fuel to make the same power so everything internally has to be larger to flow enough fuel
