Sparks!!! Now everything is dead !!
Started by Canadian1968, May 28, 2012, 07:06:19 PM
Canadian1968
Had some time on the weekend to pull out my dash cluster in attempt to fix my jumping speedo!!  I got started and totally forgot to disconnect my battery!
I removed the two wires that go to the back of the alt. gauge first,  then continued to pull out the rest of lights and other connectors.  As  I was moving the cluster around , either the two wires from the Alt. gauge touched each other , or touched the metal frame of the dash. All I know is a heard a little spark and tiny cloud of smoke appeared !!!  After this I obviously hit myself in the head and disconnected the battery. I finished pulling out the cluster and oiled the speedo cable hoping to fix my original problem .  Everything back in , reconnect the batter and turn the key to check I go my signal lights in the right spots...... nothing , tried to crank nothing at all , not a single interior light, or crank of the engine.  Battery is fully charged, checked fuses , they look fine.  Double checked connectons behind dash everything is fine.
What did I do!!! what are those two wires connected to that run tot he Alt. Gauge??
Suggestions please !!!
bet you burnt up the fuseable link in the engine compartment....it's near the bulkhead connector
Bryan
resq302
Quote from: A383Wing on May 28, 2012, 07:11:25 PM
Bryan
I agree.  Its usually a dark blue color with a little molded rubber "flag" that says fusible link.
Brian
billschroeder5842
Concur. I don't think you did any real big damage but I bet you popped a few fuses....
Texas Proud!
