PRNDL lamp for 73
Started by chargerjy9, August 04, 2005, 08:19:21 PM
chargerjy9
Thanks for the help regarding my turn signal flasher and map light issues, they are resolved.( 2 more parts no longer original to the car! )  However, the PRNDL lamp bulb is burned out, needs replacing.  What itype of bulb is it, where might I find one, and finally how do I change it. any advice is always appreciated
chargerjy9
1973 Dodge Charger SE 400 4 bbl,727, survivor
1977 AMC Pacer original
2011 Dodge charger R/T Max
what were the problems ?...
Bulb number is on your owners manual... anyway I can give you, is a 161 bulb
chargerjy9
Im not very mechanical minded,  but I can change the bulb, its a column mounted shifter. Im not sure how to access the bulb to change it
Not sure neither since mine is floor shifter, but hasn't to be a big deal... check behind the gear selector letering for somekind of acces cover.
about the rest of problems... did you remove that pieces or... ?
