Carb Question
Started by Lizey, May 16, 2012, 04:28:46 PM
Lizey
Will a Thermoquad carb set up for Lean Burn work on a car that has been converted to an electronic ignition?
1977 Dodge Charger SE - Sold 4/18/15
2013 Chevrolet Camaro RS
1993 GMC K1500
1943 Farmall A
Cooter
Without the Lean Burn computer, it will run half a$$ at best. Mixture control solenoids, and tamper proof idle screws are problematic.
Need to find a Pre-Lean Burn T-Q. I recommend something like an Edelbrock carb. to save hassles.
Lizey
Ok thanks. I found a carb locally that was pulled off a running 1969 Dodge Coronet with a 440. Another Thermoquad. Will this one bolt up?
1993 GMC K1500
1943 Farmall A
Cooter
Should, but the CFM rating might be a little big for a small block.
resq302
A 69 coronet with a 440 would have had a Carter AVS, not a Thermoquad on it if it had the correct carb on the car when you removed it.
Brian
Lizey
I know nothing of the car it came off of, I just know the guy I talked to had a Thermoquad from a 440 and he said it came off a 69 Coronet.
1993 GMC K1500
1943 Farmall A
471_Magnum
Here's a very good guide on thermoquads which will answer 99% of the questions you might have:
http://members.shaw.ca/crussel/thermoquad/tqguide.html
crankypat
  i have a holley 4 barrel on 383 mag motor. trying to get rebuild kit or carb... #s dont match at all..............................goes  0910    then below  list 4367-1   :icon_smile_angry:
oldkimmer
..............Try ur lean burn carb.....it should work good with maybe alittle tinkering........kim......
Back in the good old days 1968 charger rt 440 magnum . 1968  charger 383 magnum. The Beast has been Unleashed!!!!!!!!!!!!!!
