Recommendations/advice for 5 speed for 2nd Gen?
Started by XH29N0G, May 14, 2012, 07:56:18 PM
XH29N0G
I would like to change the transmission in my 1970 charger to a late model 5 speed or 6 speed transmission with an OD final drive.  I have not been successful navigating the forum for this.  I am looking for recommendations and advice?  The gears are 4.30:1.  I will not be racing the car.
Thank you,
James
Or maybe it protects us.
1970Moparmann
This is my personal opinion.  I have a 3.73 gear in the back and am running a TKO 600 Keisler.  Based on my setup I couldn't see having a 6 speed.  If you have a 4.10, then probably.
The new Keisler does not need any modification to the tunnel.
Good luck.
It depends if you want a bolt in unit or if you are going to modify the floor ,cross member & mounts .
Tony Edler at Classic can set u up with Tremec TKO systems for a bolt in & is better to deal with than Keisler . next to that the T56 Viper trans is a great swap , but it is far from a bolt in
XH29N0G
Thank you.  This helps.
Out of curiosity,  for a manual transmission is there an ideal drive ratio for first gear?
For instance, with a 4.30 and 2.89 with the TKO600 I get a ratio of 12.5.
matrout76
Quote from: Chryco Psycho on May 15, 2012, 12:19:42 AM
Do you have any other info for "Tony Edler at Classic "?  Does Tony have a website?  What is his contact info?  What comes in his kit?
Thanks!
Matt
RamZCharger
I just went through this exact exercise and decided on the Keisler TKO 600, rated at 600 HP with matching hydraulic clutch.  Here is a good youtube video review with pros and cons - http://www.youtube.com/watch?v=1zIwltdD_ZY.  I have heard that there is a learning curve on the 2nd to 3rd shift, as the review illustrates.  I have a good friend with a monster engine who uses this tranny, and swears you cannot shift 2nd to 3rd at the top of the power band.  I talked extensively with Keisler, and upgraded my synchros for like $100 (discounted) and they said this would fix the shift issue, although I do not plan on shifting at 9 grand.  Yet to be installed, but perhaps this may give you some insight.  Also, there are number speed analyzers out there so you can play with your gear ratios.  Good luck!
WhiteOnGreen
XH29N0G
Thanks again.  All of this information helps.
