DIRTY WHITE BOY'S 68 BUILD UPDATED 3-22-14
Started by cdr, April 18, 2012, 09:49:33 PM
cdr
well i got my torsion bars back in ,rack & pinion installed,headers,& upper a arms installed,everything from engine down,k frame & lower susp will all come out & redone later,after body & paint,gotta keep it movable under it own power & this is a good way to fit for header & rack & pinion clearance,example i need a different oil pan & tti headers for every thing to clear
cdr
cdr
cdr
cdr
cdr
cdr
well today got my firewall gasket kit,so put the ebrake& brake pedal assy's installed,master cyl,put stg column in,still gotta hook up the steering link to rack,installed ac compressor,water pump housing,alt,stg pump & got all pulleys to line up& installed battery tray,almost able to crank it up again,so i can move it out of the garage & do a major clean up of the garage,i am very messy,as my wife says lol,the will pull the iroc z in the garage ,finish putting it back together,so i can sell it to help fund the charger, thanx
cdr
m
cdr
m
cdr
m
cdr
install radiator
cdr
m
nvrbdn
70 Dodge Charger 500
70 Duster (Moulin Rouge)
73 Challenger
50 Dodge Pilot House
440
Why take the time to paint everything but not paint the lower arms and swaybar, you already had everything  off  :shruggy:  only need to paint K member then when you drop the engine.
cdr
Quote from: 440 on May 06, 2012, 08:41:38 AM
the car has to be able to be moved,this is a mock up of parts,yet car does run,when my iroc z sells,i will then be able to build the engine,my a 518 overdrive trans is at the trans shop getting built,when the engine & trans are done will drop k frame,just undo upper bj's & a few other things, engine trans & all,then rebuild the rest of front suspension ,blast & paint k frame,the way i am doing this resto it is not creating that much double work,point is car is movable,& the next step is finish body & paint,then the drive train & everything will already be trial fitted i.e, headers,rack & pinion ect,ect
cdr
putting sheet metal back on so i can finish rt qtr panel & block sanding,gotta keep the lines straight
cdr
cdr
cdr
not going to use this tunnel ram but i got bored & had to get a pic with it
Nothing wrong with playing.  Keeps the creative juices flowing.
nvrbdn
73 Challenger
Nice progress Charlie  :2thumbs:
That car looks very solid from the get-go !  :icon_smile_cool:
Keep up the good work  :yesnod:
cdr
Quote from: firefighter3931 on October 14, 2012, 07:36:45 AM
thanx Ron the car spent most of its life in Oklahoma,ark,& texas the car has very little rust,the rt quarter was all bunnndo & i knew that when i got the car.
