DIRTY WHITE BOY'S 68 BUILD UPDATED 3-22-14
Started by cdr, April 18, 2012, 09:49:33 PM
cdr
cdr
cdr
also i used a heat gun to heat up fins that where bent & straightened them.
if you look at this close you can see on the pass side lower the grill has a bow to it,i took some flat thin steel strips & gently clamped it over the warped section,the heated it up & the let it cool.... WALLA no more bow
cdr
Budnicks
cdr
cdr
cdr
NHCharger
Grille looks awesome. Neat trick to straighten out the bow. I'll have to rememeber that when I get to mine.
72 Charger- Base Model
68 Charger-R/T Clone
69 Charger Daytona clone
2014 RAM 2500HD Diesel
green69rt
Nice work Charlie, maybe mine will look as good, someday.   No work today, 101 outside.
cdr
thanx guys got some more done,grill is finished!!!!! i have gotten the three things that i dreaded doing,the grill,a/c box,& dash assy.DONE.
cdr
cdr
cdr
Budnicks
charge69
I don't know how you do it in this heat! It is all looking great.
Before you know it, you will be driving that beauty!  Nice job, sir!
cdr
Quote from: charge69 on August 07, 2013, 04:47:30 PM
THE ONLy reason i can do anything is i have an ac window unit in the garage  :yesnod:
cdr
cdr
cdr
I hope you put some bolts in the bolt holes. :scratchchin:  It might be fun bolting in your seatbelts if you didn't. :popcrn: :popcrn:  It does look good though :2thumbs:
cdr
cdr
well my restoration has changed direction a little,i was going to hang doors & fenders & then block all the lines & then take the car apart & paint the doors & fenders off the car,i decided to paint the jams, finish the BASIC body work on the doors & fenders,spray the final coat of clausens filler sealer,cut in the doors & fenders with black & put them all back on the car for hopefully the last time,i will then finish the rest of body work on the 1/4's & roof & do the final block sanding.
with the way i am doing it now, i can put my ac box , dash assy & install the windshield
dont laugh i had a fight with the seam sealer,my hands have gotten so shaky i had seam sealer everywhere  :smilielol:
cdr
cdr
