DIRTY WHITE BOY'S 68 BUILD UPDATED 3-22-14
Started by cdr, April 18, 2012, 09:49:33 PM
cdr
this is the 900 CFM EFI THAT MY BUDDY gave to me, it needs to be sent to holley for a wide band o2 upgrade ,its not as easy to tune as some of the newer set ups ,but its brand spankin new & free  :icon_smile_big: it will go on an indy single plane intake max wedge port,thanx DR FIX
cdr
my 3 in stainless x pipe system magna flow
cdr
these are what we run on DR FIX'S 10.9 TRANS AM STRAIGHT through,not all that loud
cdr
some hemi springs i got from tony alley,he has a 69 hemi rr that he mini tubed & sold me the springs cheap
cdr
junk tunnel ram just havin fun
cdr
now for some garage shots,moral of the story is when doing a restoration you will need about 4 times more room than you think
cdr
cdr
this is my jwbellhousing to convert my a518 overdrive for a big block
cdr
this is my a518 overdrive
cdr
my 3200 stall lock up converter
cdr
alum rod for my 511 build
cdr
southern & proud
to be an american  :yesnod:
Best thing is, when you get the car together, you get a clean garage as well. :lol:
NHCharger
Quote from: cdr on October 14, 2012, 12:17:47 PM
Man, ain't that the truth. Looks like your making some progress.
72 Charger- Base Model
68 Charger-R/T Clone
69 Charger Daytona clone
2014 RAM 2500HD Diesel
cdr
got my flow bench home & now its cooler out side,im tryin to get a little work done on my heads
these are the 440 super stealth & this is for a street motor,my testing cyl adapter is 4.250 bore diameter, i will machine it to 4.4 when i can get to it.
otb .200 140              short side work,& raise port window to max wedge      .200 160
    .300 202              2.14 valve,30 deg back cut,NO SEAT work done yet    .300 220
    .400 242        .400 260
    .500 256        .500 287
    .600 267        .600 307
    .700 267        .700 323
        .800 334          to be continued
cdr
well got some needed parts for the charger for christmas,thanx to some awesome people,so i'm going to finish my metal work,fitting the outer wheel house & then i can hopefully finish the quarter panel  :icon_smile_big:
cdr
scraped off the under coating & sprayed edges with weld through primer & red oxide for the rest,got the outer wheel house fitted ,will weld in tomorrow ;D
cdr
cdr
cdr
cdr
cdr
got the outer wheel house welded.now some grinding & seam sealer  :yesnod: then to the trunk drop off
Cooter
VERY Nice cdr. I see your on the ground, in a small shop. My hats off to ya. Excellent work.
cdr
Quote from: Cooter on January 09, 2013, 05:52:54 PM
thanx cooter ,yep it is small,what sucks is when i got sick & shut down my shop, my lift is still there & no room here at the house for it.
cdr
cleaned off & primed the inner rocker
welded up some holes
& fitting this huge, gigantic ,gargantious quarter panel
