Radiator lower outlet question
Started by mcain, April 08, 2012, 09:47:15 AM
mcain
sorry in advance if this is a dumb question but I am putting a 440 in my 66 charger.. the lower cooling outlet on the engine is on the passenger side but the lower outlet on my radiator is on the drivers side.. it is possible to have a radiator shop move the outlet to the passenger side?  thanks!
I would think a quality rad shop could do nearly anything you wanted them to.
If it were me I would change the water pump housing to the more common inlet on drivers side. This will align the two fittings and eliminate the obscured timing mark that yours has.
Depending on the rad shop and your mechanical abilities, John's suggestion could be cheaper too.
mcain
