Removing A Steerling Column From A 1973 Charger
Started by irish_in_ny, April 04, 2012, 03:27:57 PM
irish_in_ny
How much of a job is it to remove a steering column from a 1973 Charger? Do I only have to remove the two bolts at the base (on the inside firewall) or is there more to it than that? Cheers in advance for any reply.
3 nuts on column bracket below the dash ( 7/16" hex head )
3 bolts at firewall. ( 1/2" hex head )
either remove bolts from stering colum rubber puck coupler at engine bay, OR coupler at steering box
of course unplug all wires ( ign, turning signal, ign key courtesy light if pressent )
IF column shifter... unlink the shifter linkage at column lever on engine bay
