Best Clutch
Started by 70rr 69ch, March 12, 2012, 12:48:02 AM
70rr 69ch
Hi guys! I replaced my clutch assembly when I did my car 5 years ago,went with mopar per clutch and plate 10.5 inch. Problem is I can't find part number for just the disk?how different are the disks from other manufactures and can I use one with my pressure plate,any help would be great thanks :shruggy:
70rr 69ch
A little more info car is 1970 440 4speed.had some trouble with the shifter when I first put it on the road,I think I slipped the clutch a couple of times.had a rear engine leak that didnt help.I'm hoping to just change clutch disk any help or suggestions thanks guys :shruggy:
the 10.95" disc will fit where the 10.5" is , you can go with ceramic or velvet touch that would be resistant to oil .
I have used McLeod products & have had no issues , they make good clutches
Budnicks
I've had good luck with McLoed, Hayes, Zoom, Ram & Centerforce
