Ground off washer motor pump mounting location 73 Charger
Started by JonSellards84, February 02, 2012, 11:56:11 AM
JonSellards84
Does anyone know wher the factory locaton for the ground off the washer pump motor goes
usually it get a terminal sleeve kind inserted on the mounting ears at washer reservoir to be grounded with the same washer reservoir holding screws
If sleeve kind terminal is not pressent, eyelet terminal to the same mounting screw will work
