welding in floor pan
Started by deanj309, January 29, 2012, 09:59:55 PM
deanj309
Hello guys I spent this Sunday. Removing the paint from  the edges and for the frame rails of my new one piece floor pan for my 68 charger to be welded in. I know the rear footwell pans over lap and get welded but do I need to trim anything off to connect the full pan to the footwell or is there a overlap,if so could someone post a pic on how it supposed to be thx!
richRTSE
If your are using the AMD pan, no trimming is required. The front lip of the new pan should get clamped and welded to the lip on the bottom of the firewall, and then welded to the frame sections, on the tops of the rockers, and in the back to the rear footwell pans. I just did this to my car, and it fit pretty well. I used alot of vise grips and sheet metal screws to lign it up. After I had the pan clamped in place, I went under the car and marked the new pan with spray paint so I could see where the frame sections were, then I removed the pan and drilled all my holes for the welds. Then I reinstalled the pan and started welding at the firewall, then worked my way back. The only "problem" i had was the contour of the pan where it sits on the crossmember framing was quite right, and I did have to massage it with a hammer and a block of wood to get it tight against the frame to weld it. Make sure you're happy with the fit before you start welding, take your time, and you shouldn't have a problem. You can see all the welds in these picts...
:2thumbs:
deanj309
Thx! Richrt, iam useing full amd floor and footwell just like yours. pics are going to help a lot! Hopefully I will have my pans in tonight.and one step closer .once again thx! for your responce.... .see ya on the road! :coolgleamA:
nvrbdn
hey dean, you gona make it down for monster mopar in june?
70 Dodge Charger 500
70 Duster (Moulin Rouge)
73 Challenger
50 Dodge Pilot House
deanj309
Hey! I am not sure if the car will be ready,but iam goin to make it.but it dosnt mean I won't give it one hell of a try! Got all sheet metal...ect. just like everyone tryin to get a window to get it in.will you be goin
nvrbdn
yep we will be there. if the car isnt ready, make sure you come down anyway. 41husk and i are talking about mabey getting a swap spot. will definately have the charger there. it is a great weekend and plenty of parts to pick through for your restoration. :2thumbs:
73 Challenger
