which type fan to use???????? electric or belt ?
Started by 911bear, August 04, 2005, 02:14:35 AM
911bear
 ???  hey guys and gals which fan cools better an electric or a 7 blade clutch fan i know theres the horse power thing an electric gives you less drag  ??? but which cools the best   :icon_smile_question: 911bear
1974 DODGE CHARGER SE BROUGHAM - CURRENTLY
CARS I HAVE OWNED :
4 - 1969 DODGE CHARGERS
1 - 1970 PLYMOUTH GRAN FURY W/ COVER UP HEADLIGHTS 2 DOOR
1 - 1970 PLYMOUTH ROADRUNNER
2 - 1973 DODGE CHARGERS
1 - CHRYSLER CORDOBA
1 - 1984 DODGE RAM TRUCK
Charger4404spd
Plumcrazy
Depends on the electric.  There are a lot of different ones with varying cfm ratings.
For a street car the MP viscious fan package is hard to beat. It is belt driven with a clutch unit, btw.
But make sure you have room between the rad and the engine.  The MP unit has a clutch that seems to be too long for some applications.
Deano
By no means do I know as much as Ghoste and Ron. But i have a Flex a lite dual electric fan setup in my charger and it stay's alot cooler than others in town with the clutch fan. We had a parade and while everyones car was to the point of the owners concern I had no worries, I ran a even 170-180 dergree's and the air temp was 90 plus degrees outside. While at idle the electric will  put out max air volume ( mine is 2500 CFM) vs the clutch fan the more you rev the more air. There are many pro's and con's but I tend to lean towards electric fans. Hope this helps.
                                                          Deano
69 Charger SE Triple Green
04.5 2500 4X4 Cummins QC Ram Graphite
04 jeep GC Limited Graphite
Combat Boots Green
charger72
my 72 used to always tend to overheat during hot weather. But since I put a dual fan in front of the radiator, I never have a problem with it overheating. Have both the belt drive fan and electrics on it.
I like the smplicity & reliablity of the clutch fan
roger01
can someone list the causes of overheating.
, i havent really driven it yet but it is overheating for some reason i put a new thermastat
dkn1997
Quote from: Ghoste on August 04, 2005, 11:01:05 PM
more like too long for every application.  there are shorter clutches available for added clearance.
RECHRGED
 :haha:  I have heard of it fitting in some.  I actually had it fit in a Charger once.  It don't fit the one I have now, but...
KMPX2
dkn1997 brings up another question.  I know there are shorter clutches, but does anyone have a list with brands and part numbers for them?
bull
I learned a little about all this yesterday from a radiator shop owner. If you have a stock radiator you should be good to go with a clutch fan. I've yet to really understand why people use electric fans other than for sitting in traffic because they are a lot less adept at moving air through a radiator. If you've upgraded to a 3 or 4 row system forget the clutch (no room), forget the electric fan (not enough pull) and go with the straight, bolt-on 16"-17" fan.
roger01
would not having a fan shroud be a coause of overheating while idleing and just sitting in the driveway
