Running an engine without a wiring harness
Started by Highbanked Hauler, January 13, 2012, 03:22:39 PM
Highbanked Hauler
   What is the best way to run an engine  in the car with the least amount of wires and keep the alternator charging ??   I am looking to run the 440 for  half to an hour and the radiator is in and trans is connected.  I understand its not a good idea to power a coil off the battery for any length of time, is this true ???
92 Cummins Turbo Diesel
04 PT Cruiser
richRTSE
Not sure about the charging, but for the coil question I think it depends on what you're using for ignition. If using a stock chrysler ignition, then just use a ballast resistor to feed the coil. If using an MSD ignition and coil, no ballast resistor needed. The factory setup uses something like 7 volts at the coil for running the engine (12v while cranking/starting) and the MSD setup uses a constant 12v....
edit: I probably shouldn't say the MSD setup uses a constant 12volts at the coil...probably the right thing to say is the MSD box supplies the "correct voltage" to the coil, and no ballast resistor is needed...
:icon_smile_big:
well you need 12v from the battery to the start relay & the coil to run it , short the start relay to start it .
the charging system is no harder .
For 70 up you need  12v to both the alt field & reg , the reg has to be grounded & the main output wire from the alt has to return to the battery terminal on the start relay + you need the second field wire to return to the reg [green wire]
For pre 70 you need 12v to the reg & a wire from the reg to the field wire on the alt , the output still goes back to the battery terminal on the start relay
Highbanked Hauler
    The Dist.  an Accel  dual point and I wondered about running the coil off the ballast resistor. I would think I could run a wire from the alternator  to the  main  wire of the starter relay and it would feed the battery. :shruggy:   Obviously  I would have to feed the ballast resistor too.
     Yes it is a 69 Charger
04 PT Cruiser
yes the coil feed is better with a ballast resistor in it .
the dist connects to the neg coil terminal
