8 and 3/4 rear end question
Started by paul smart, December 31, 2011, 03:59:43 AM
paul smart
hey fellas im running a 742 case in my 68 and need to replace the pinion bearings the big pinion bearing(at the base of the teeth not the seal end)im needing a part number as when i heated it to remove it it blued from the heat and unreadable HELP PLEASE :eek2:
flyinlow
Don't have the bearing number, however Autozone carries Timken bearings for the  1.750 pinion shaft  8 3/4" axle.
HM 803149 -bearing
HM 89410 -race
AZ numbers
