which carb?
Started by ChargerST, December 21, 2011, 03:30:20 PM
to me it looks like both would perform as well , the main difference seems to be the billet base plate & metering blocks
ChargerST
Thanks. The metering blocks on both carbs look like they're billet aluminum imo. What's the advantage of having a billet base plate other than looks and weight?
Quote from: ChargerST on December 22, 2011, 04:13:00 AM
On the cheaper carb the baseplate/metering blocks are not billet aluminum....that is the only difference that i can see. Both should work fine for a street type application.  :2thumbs:
ChargerST
Thanks! I'll get the cheaper one then if there isn't a difference in performance!  :2thumbs:
