dana 60
Started by billssuperbird, November 10, 2011, 04:27:43 PM
billssuperbird
i have a 8 3/4 rear end in my car.but i may be getting a 1968 dana 60.do i have to change the drive shaft. and what more do i have to do. :shruggy:
maxwellwedge
What trans do you have?
68RED4SPEED
Yes The Dana is 1.12" longer from c/c axle so the driveshaft has to be same 1.12" shorter.
billssuperbird
440 4 speed :2thumbs: and the 68 is a 440 4 speed
maxwellwedge
You may be ok....maybe measure the center to center of the drive shaft length (at c/line of u-joint) and also how much of the slide in yoke (at the trans) is showing.
maxwellwedge
Quote from: 68RED4SPEED on November 10, 2011, 04:59:49 PM
Are you talking about the width of the Dana? That wont have any bearing on the d/shaft length.
BrianShaughnessy
The U joint yoke / flange on a Dana is about an inch closer to the transmission,   therefore the driveshaft is about an inch shorter.
4 speed dana shafts are few and far between....  and probably bent.    And Plymouth and Dodge shafts are also different due to the 1 inch difference in wheelbase.
I've posted a page from the gtx / road runner / charger resto book with driveshaft lengths on it before...  having trouble finding it right now.
68RED4SPEED
Quote from: maxwellwedge on November 10, 2011, 05:11:05 PM
No, from c/c axles to c/c yoke 8 3/4 has 12.35" and the Dana has 13.47"
BrianShaughnessy
Found it.
billssuperbird
billssuperbird
 :woohoo: i got the dana.it has the small backing plates. can i put my bigger plates on from my 8 3/4 rear end.and i need a pinion snubber+ the 3 bolts. any one have this for sale.
BrianShaughnessy
Quote from: billssuperbird on November 12, 2011, 06:27:15 PM
Congrats
Rear brakes all interchange... go for it.   Generally cars with front disks got the 10" rears as opposed to the drum cars that got 11" all around.
meanwhile check ebay for pinion snubber... http://motors.shop.ebay.com/i.html?_nkw=pinion+snubber+dana&_sacat=6028&_odkw=pinion+snubber&_osacat=6028&bkBtn=&_trksid=p4506.m270.l1313
billssuperbird
thanks for the help :2thumbs: do the axles come out the same as a 8 3/4 axles. :shruggy:
billssuperbird
the axles pull out the same on a dana as a 8 3/4 :shruggy:
elacruze
Quote from: billssuperbird on November 12, 2011, 07:01:55 PM
Yup just get the bearing plates off and pull them out.
1968 505" EFI 4-speed
billssuperbird
