vin stampings
Started by charger01, November 03, 2011, 12:01:55 PM
charger01
I have a 440 hp non original motor in my 69.  I know of the stamping on top of the motor , but is there somewhere on the motor with the entire vin of the car it came out of ?
 can you post the vin or numbers  you find  & what location !!
what are the letters / numbers stamped on the top pad ??
charger01
Mine is an hp 440 2 e block if I remember correctly.  Thinking late 68.  Will try to get the rest of the numbers tonite .  Thanks for ur help.
 :2thumbs: :cheers:
  E 440  , its a  1969  motor   HP  high performance  motor ,  the 2 is built on the second shift
 late 68 ,   more than likley its got the the whole vin stamped  on the passanger side of the block  on a machined pad above the oil pan rail !!  yellow arrow location in picture i posted !!
:popcrn:
XS29L9Bxxxxxx
Some of the other stamping of the pad have to do with oversized/undersized bearings, etc.
Lennard
Quote from: tan top on November 03, 2011, 12:47:12 PM
Mine has got no numbers where the left arrow is. I will check the other place for numbers.
I bought the 440 HP2 from Craigslist about a year ago for $400.
Quote from: Lennard on November 04, 2011, 02:11:57 PM
whats the letter before the 440 on the top pad !! if there is no stamping where the yellow arrow is its prolly a 68 & earlier block !!  or if there is a machined pad in the location of the yellow arrow &  the pad is blank  , maybe a warrenty block or parts counter  :scratchchin:
:popcrn:
Lennard
Finally had the time to take a look at the numbers on the block. It says E440 on the top pad and 9C225852.
E is the year code for 1969, the partial VIN is from a '69 car built at the Jefferson (C) plant...in '69 the Jefferson plant built Chryslers and Imperials.
Lennard
Thank you for the explanation John. :thumbs:
maxwellwedge
Could you get a TNT 440 in any of the cars built at that plant?  :scratchchin:
Lennard mentioned his had HP or HP2 on it.
Budnicks
By the oil pan rail there should be a flat pad on the side with #'s also unless it's a replacement block maybe..
472 R/T SE
Quote from: maxwellwedge on November 09, 2011, 04:29:13 PM
That's the first thing I thought.
69CoronetRT
Yes. the TNT was optional on Newports, Newport Customs, 300 and New Yorkers.
Tilar
So the TNT and the HP are the same?
Dave
maxwellwedge
Quote from: 69CoronetRT on November 09, 2011, 05:52:02 PM
Thanks - Wasn't sure what cars were built there.
maxwellwedge
Quote from: Tilar on November 09, 2011, 06:34:35 PM
Yes - TNT was what the HP440 was called in the Chryslers.....Like Magnum on the Dodge etc.
Lennard
So the '69 HP2 440 I have did not come out of a '69 Charger but out of a Newport or 300 or New Yorker?
69CoronetRT
Quote from: Lennard on November 10, 2011, 01:57:00 PM
IF the vin on the side of the block is from the C plant AND the pad is stamped HP then yes.
Are you sure the VIN stamp is a C and not a G? Sometimes the stamps are light and you can miss the tail of the G. A "G" plant HP is more likely due to the larger number of Charger R/Ts, Coronet R/Ts and GTX's built at that plant compared to the number of Chryslers that came with the TNT.
You can get somewhat of a correlation between the engine assembly date on the pad and the VIN to help determine which plant the engine came from.
Lennard
Darn it, I thought I had found a nice block for my '69 Charger... guess I have to go for a 426 Hemi anyway then. :scratchchin:
The top pad reads: E440  1 10  HP2
Oilpan rail reads: 9C225852   It is definitely a C and not a G.
maxwellwedge
It is still a good engine, year, HP etc for you. A non-matching block is a non-matching block no matter what.
69CoronetRT
Quote from: Lennard on November 10, 2011, 02:21:44 PM
The engine assembly date to VIN number does match better with a C plant car than a G plant car. :Twocents:
Lennard
Quote from: maxwellwedge on November 10, 2011, 02:26:44 PM
You are right about that.  :yesnod:
Well, I have a few years to go before I am ready to bolt in any kind of engine so plenty of time to think about it.
Thanks for the info guys, much appreciated!
, i got a E series 440 in mine , came out of a 69 imperial , think the second digit is C also , will check later
yep mine C    :yesnod:
    9C293241
bakerhillpins
So if the VIN on the block isn't the complete VIN but rather starts at (say in 69) the Engine id how can you be sure that there are not 2 engines with the same #s?
I.e. the stamping is Engine/Year/Plant/Sequence
So are we guaranteed that in a given year that 2 different cars from the same plant didn't get the same sequence number?  Since plants made more than one model were they given different ranges for sequence number?
One great wife (Life is good)
96' VFR750 (Sweet)
Capt. Lyme Vol. Fire
