Battery Tray Support Arm
Started by jdiesel33, November 02, 2011, 10:09:06 AM
jdiesel33
Trying to put battery tray back in. From what I thought I remembered when taking it off a few years back and what some of the pics on here are showing is the the support arm is attached to the front, inner corner of the tray and then goes up diagonally and attaches to the upper shelf of the engine bay by the fender tag. However, i do not have a hole there for it to attach to. Were there any other way that these arms went? where else would it attach? 68 Charger, 440.
1968 Dodge Charger R/T
PP1,Black Hat, Black Stripes
this any good !!  have this one saved on computer !! if you need anymore let me know
second picture !! there are two lower brackets the other one is exactly the same but at the other end of the vacuum can
jdiesel33
That pic is exactly what is puzzling me. I dont have a bolt hole or screw hole or any kind of hole up there on top to attach the arm to.  :shruggy:
maxwellwedge
Ckeck underneath the inner fender....it may have been welded/bondo'd or sheet metal patched over.
UFO
Was the inner fender replaced?
Not sure if the repo's would have the nut already welded on or not.
jdiesel33
Fender wasnt replaced, but I suppose there is a possibilty someone patched the hole.  :scratchchin:
That is prob what happened. Thanks guys
