73 Charger colum shift to floor shift
Started by JonSellards84, October 27, 2011, 06:23:25 PM
JonSellards84
Hey converting a 73 charger column shift to floor shift but is there any templetes on where to weld the floor shift floor brackets has any done this conversion Im would like to do research before welding thanks for your time
devilgear
Are you talking about putting a stock floor shifter in or aftermarket? I put in a Hurst shifter in my 73. I did not weld anything, but I did make a bracket for the shifter to sit on the hump because of the offset in my console. I just used sheet metal screws to secure it and it works great.
E5 Charger
This is for a 71, but it should be the same (I think). I'm planning the same thing. I've collected all of the parts and now just have to get around to doing it.
http://www.dodgecharger.com/forum/index.php/topic,50082.0.html
CDN72SE
I'm going to do the same thing in my '72. Hadn't seen that link, thanks for posting.
1972 Charger SE
JonSellards84
hey thanks for postin that link man i got my shifter in tonight no problems thank you again for the link
E5 Charger
Hey no problem. That's what we are here for.
