changing plugs in a Hemi
Started by Fred, October 19, 2011, 01:33:59 AM
Fred
Does anybody have the answer on how to prevent oil running into the combustion chamber while changing the spark plugs in a hemi?   :scratchchin:
68X426
No. But then it is very small amounts that get in. I just fire it up and go.  :popcrn:
We Want to Help You.
1958 Dodge Pick Up, 383, loud
1966 Dodge Van, /6, slow
Fred
So do I but first I smoke out the garage!!
Challenger340
LOL !
So many here....... wish they had THAT problem ?
:cheers:
Only wimps wear Bowties !
Cooter
Not sure as I'll never be able to own  a Hemi, but sounds like it might be time to do plug tube seals...
gtx6970
let it sit a few hours before removing the plugs helps quite a bit
Scaregrabber
Do you pull out the spark plug tubes? I leave them in and slip a piece of vacuum hose over the head of the loose plug and pull it out. Milidon makes (or maybe made) tube seals that slide into the sparkplug hole and then the spark plug tube slides into it. I have an extra set of these if you're interested.
Sheldon
maxwellwedge
Those Milodon things are good. They also help with the thicker than original valve cover gaskets.....helps get the tube fitment back in line.
