mini starter life?
Started by flyinlow, October 11, 2011, 08:31:41 PM
flyinlow
Anyone wearout a mini starter?
I have abiut 23K miles on the 446 and it still starts it  fine. I am going to take the headers of this winter and was debating changing out the starter?
UFO
Don't fix it if it ain't broke.
The one you put in might be a dud.
I got 143,000 miles on the OE mini starter in my 94 Dakota...does that count?
FLG
If it aint broke dont fix it.
the only problem I have seen with the mini is the two contacts wear in the solinoid , you can get new contacts for about $4 at a rebuilder & install them in minutes , to get to them there is 3 - 6 or 7mm screws on the end cap , remove that & you can check the contacts to see how worn they are
flyinlow
Quote from: Chryco Psycho on October 12, 2011, 08:57:19 AM
I will check  out the contacts for sure. Sounds like the starter is pretty dependable , I will reuse it.
Thanks for the replys.
