Headlamp vacuum hoses
Started by jaak, September 25, 2011, 07:00:05 PM
jaak
I thought I had everything hooked up right, but when you crank up the car the headlamp doors flip up on their own (even with headlamp switch in the off position), and stays open even when you flip the headlamp switch to on?
Any clue on what I did wrong, or any test procedures?
Jason
  :scratchchin:
yellow/amber striped vacuum line goes to the top vacuum port on the headlamp door actuator
green striped line goes to the vacuum canister
plain /no stripe vacuum line goes to the bottom port on the headlamp door actuator
piture below is the  order on switch  ,  just for referance   :yesnod:
jaak
Quote from: tan top on September 25, 2011, 07:23:56 PM
 :scratchchin:
Thanks, although the original striping is not visible on my hoses, Im sure I can trace everything.
jaak
Thanks, got them fixed, had 2 hoses crossed up, work fine now!
Jason
Quote from: jaak on September 26, 2011, 10:21:04 PM
Jason
:cheers:     thats good it was a simple fix  :yesnod:
