No turning back from here.
Started by Ryan, September 17, 2011, 08:20:12 PM
Ryan
Got the cutting wheels out today and this was the result.
I painted this car when I was 19, did what I could with the money I had at the time. Now that I've got the resources it's getting the resto that it deserves. I'm replaceing the goodmark trunk panel i installed several years ago and I'm replacing it as well as the quarters, tailpanel, Dutchman ect... With new AMD parts. More pics as progress continues.
69 charger r/t Triple Black
   572 HEMI, Passion 5 speed, 4.10 Dana under construction
2014 viper TA
lexxman
Yep your right,there no going back. Just remember its all up hill from here. :2thumbs:
Ryan
Sheetmetal came in today!!!! The quality of the AMD pieces looks excellent. Pics coming soon.
2014 viper TA
mauve66
Robert-Las Vegas, NV
NEEDS:
body work
paint - mauve and black
total wiring
PW
PDLKS
Tint
trim
alignment
Ryan
Pics of outer wheelwell sectioned in.
Test fitting trunk floor
Once I can verify a good fit I will be blasting the rear of the car then epoxy on the inside of the frame. Trunk floor will be getting spot welded with my new miller spot welder :)
2014 viper TA
 nice work  !! looking good   keep the pictures coming  :2thumbs:
lexxman
Man you just gotta love new sheet metal,it's coming along nice. :popcrn:
Ryan
Well after discovering that AMD makes these trunk pans 1/2" too short I had had to extend it to get everything to line up right.
Now it lines up with the quarter cap.
Weld ground down.... Can't even tell.
2014 viper TA
Ryan
Welded up the gas tank brackets
Also got to try out my spot welder on the spare tire bracket.
Just need to do some sandblasting and I can weld this thing in.
2014 viper TA
 :scope:  ........ looking good  :yesnod: ......... :popcrn:
lexxman
Ya,I had the some problem with the floor being too short,I was thinking it was just me. Things are looking good. :2thumbs:
Ryan
Thanks!
Was finally able to get some blasting done. Just about ready to spray some epoxy inside the rails then this trunk gets spot welded in place.
2014 viper TA
Ryan
Rails blasted clean.
Epoxy sprayed
Trunk will get one last test fit tomorrow then i will apply the weld through primer on the tops of the rails and underside of trunk floor. Then time to start spot welding.
2014 viper TA
lexxman
Ryan
Progress was made today.
Epoxy and weld through primer
Trunk pan cleaned up
Trunk fitted
First few spot welds
More
2014 viper TA
lexxman
Useing the spot welder must be nice.Not much if any cleaning after. :2thumbs:
Silver R/T
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
Ryan
Quote from: lexxman on November 18, 2011, 05:08:36 PM
It is nice but I am a little worried that the welds that I need to use the long 18" tongs on are not the greatest. May have to mig in between the spot welds.
2014 viper TA
lexxman
If your worried about the spot weld not clamping tight enough you can hold the tigger for a few seconds longer. And you should be able to adjust the tention. I have a spot welder at work and it looks the same as yours.
Ryan
Quote from: lexxman on November 18, 2011, 07:40:19 PM
Tried just about everything with the 18" tongs.... More pressure less pressure, more trigger time ect... They just don't put out the current that the smaller tongs do. Maybe I need to try out a lenco or something besides the 220v miller.
2014 viper TA
lexxman
My only other idea is to do some plug welds by drilling holes in one of the two pieces and then use a mig welder to fill the hole. :Twocents:
