synthetic oil
Started by Silver R/T, September 02, 2011, 12:22:53 PM
Silver R/T
Who's running synthetic oil in their cars, which brand did you go with and why?
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
WHITE AND RED 69
I just picked up the new royal purple hps oil. Has the zinc additive and is supposed to be perfect for performance motors. I plan on doing an oil change tomorrow to see how good it really is. Its kind of pricey but not nearly as much as the xpr line.   :cheers:
http://royalpurple.com/motor-oil-hps.html
http://www.jegs.com/i/Royal+Purple/831/31140/10002/-1
1969 Dodge Charger R/T
1999 Jeep Grand Cherokee
1972 Plymouth Duster
Budnicks
I run Royal Purple in my 99 4x4 Dakota & Torco Racing oil in my RR, just an old habit on the Torco, I never had a failure due to oil with the Torco stuff... Had some issues with other brands, especially when running Blown Alky Combos & diluting the heck out of the oil... No issues with the Torco synthetic or std. petroleum based racing oils, they aren't cheap...
Charger-Bodie
I run Amsoil In my Hemi cause thats what Tim @ FHO said to use.
Brass
I use Brad Penn partial synthetic.  Plenty of zddp without needing an additive.  My car has a minuscule dribble at the rear main so I switched from Royal Purple.  I thought Brad Penn would strike a good balance; enough synthetic for added protection but doesn't intensify the leak.
7chargers
I run AMSOIL'S new Z-ROD made specifically for muscle cars and the newer performance cars, challenger/charger/camaro/mustang. It has  the zinc additive that high performance motors and flat tapped cams most mopars run for protection. I run it in my charger and coronet and my oil pressure has elevated and my actual fuel economy is better, plus when or if you store your car the zinc and formula in it actual bonds to your engine componets for a good protection between start-ups. Check out this web site for more info. http://cooksperformanceshop.com
1970Moparmann
Brad Penn.  Can't beat the oil for $60 a case.  Has the Zinc additive and is half synthetic.
Ron suggested I use and I am. :2thumbs:
flyinlow
Mobil One 15w-50 + comp cam break in addative. 22K. sofar. on a mild street build 446.
resq302
Im using the new Valvoline VR-1  synthetic race oil.  Has a nice Royal Blue color to it.    All in all compared to the original VR-1 conventional oil, it does seem to idle smoother and make the engine run a little cooler than the conventional oil.
Brian
