gearbox noise,maybe
Started by westcoastdodge, August 30, 2011, 03:38:42 PM
westcoastdodge
hey guys got a small issue when i accelarate harshly i can hear a noise like a fanbelt slipping noise but thats tight??
you dont think it could be the gearbox making that noise :eek2: oh yes torquflite 727 :2thumbs:
I don't care what is is designed to do,I want to know what it can do.
Gene Kranz
FLG
i assume it dosnt do it if you just rev the engine?
have you checked your u joints?
westcoastdodge
hi FLG,the u-joints are both good and well greased,does not make the noise when just revving the engine,just seems to do it when you have it under load :shruggy:
would an auto box make any sort of noise if slipping??
Gene Kranz
70 Charger RT
Take some "door ease" and lubricate your belt with it when engine idling.  Watch your fingers!  If that helps to remove your noise, them buy a new belt and adjust to proper tension.
70 Charger R/T - 440/6
07 BMW 328iS
04 GMC SLE 2500 Diesel
bobs66440
I had the same problem. No matter how tight I made the belts, they squealed (old and new ones). I put some belt dressing on and it went away...
westcoastdodge
cheers guys,going out in her now,will put some belt dressing on and see how she goes :2thumbs:
Gene Kranz
FLG
If it doesn't make noise from a rev id rule out the belts.
charger Downunder
Check that your fan isn't scraping the radiator. by having a bad gearbox mount or the bolt that holds the mount in place has fallen out.
[/quote]
