Disc Brake Conversion, setup
Started by 1968 Charger B5, August 22, 2011, 09:41:39 PM
1968 Charger B5
Changing my 68 Charger's brake. Car is originally non-power drum. I have the 73 a body spindles and appropiate bearings...my question(s) are
1. Cali/pads/rotors? Do i use 73 b-body?
2. Do I need a proportioning valve? If so, from what year/model?
Rick
1968 Dodge Charger R/T
1970 Dodge Charger
1974 Plymouth Roadrunner
1998 Jeep Cherokee SRT
no you use the 10.7 " dart disc assuming you have the matching caliper adapter , if you have the later Cordoba magnum adapters you can use the 12 " cordoba rotor
