W200 Oil Pan Gasket
Started by chargd72, June 27, 2011, 03:47:34 PM
chargd72
Anyone know if it's possible to change an oil pan gasket on a '76 Power Wagon without hoisting the engine?  It's a 400 with column shift.  Don't want to pull it apart then find out I can't put it back together.
MoparSam
I haven't done it but I believe it can be done. I can get to all of the bolts on my Ramcharger's (small block and Dana 44) fairly easy. There's quite a bit of room under there.
'68 Charger R/T 440
'74 D-100 Adventurer 318
'75 Ramcharger 360 4x4 4 Speed
'78 Ramcharger 360 4x4 4 Speed
'67 Dart GT (Soon 440)
'05 Ram 1500 4.7
1/2 '71 Dart
chargd72
Thanks for the reply MoparSam.  I can get to my bolts pretty easy as well.  I was more concerned with being able to drop the pan far enough to slide it out before it hits the k member.
chargd72
Looks like I'll be the guinea pig.
MoparSam
Quote from: chargd72 on June 28, 2011, 08:47:56 AM
Ah got ya. If nothing else jack the engine up just enough for clearance.
Quote from: chargd72 on June 29, 2011, 08:39:16 AM
Good luck :2thumbs:
'68 Charger R/T 440
'05 Ram 1500 4.7
1/2 '71 Dart
