Charger Rally dash
Started by HOTROD, June 25, 2011, 12:25:34 AM
HOTROD
A friend of mine asked me another ?? would a Rally dash fit in a 69 RoadRunner ?? I know the 70 RR had the same dash as the Charger  but will it fit in the 69 ? :shruggy:
What the Hell-Dumass !
Not exactly.  The opening in the dash frame won't let you put the Charger cluster in there BUT, the frame can be changed over between the two cars.
With frame 69 to 69, 70 to 70 as the flasher switch and key ignition is moved to column in 70. (No hole next to brake warning light for flasher switch and no hole for ignition switch next to column on a 70 dash.)   :2thumbs:
