Recent upgrades on my 69 - 2018 time to clean things up
Started by WHITE AND RED 69, June 12, 2011, 08:29:06 PM
WHITE AND RED 69
Quote from: dodgey68 on March 11, 2014, 04:35:21 AM
Thank you white and red69
Just  received the lights, took 10 minutes to fit, bright suckers is right, also got rear LEDs  as well, thank you for showing them on here,,,,hid  headlights next
No problem Dodgey! The quality and ease of installation of those lights make em a sweet buy. After using them there is no way I'd go back to stock. Now post up some pics on your thread so we can see em   :cheers:
1969 Dodge Charger R/T
1999 Jeep Grand Cherokee
1972 Plymouth Duster
MackDa600
Question on your HID's:
I have a 68, already installed the housing conversion kit, now have composite H1 & H4 bulbs for low/high beams.
Getting ready to install hid ballasts, however I'm trying to keep it as clean and factory as possible. I will not be modding the factory connectors.
I want to know since the low beams go on with the high beams, did you need to install a diode on the "third" leg of the low beam connector or is there another solution?
autodynamics
To keep the low beams on with the high beams you have to add a relay at the high beam switch to keep power to the low beam side when the high beams are triggered
MackDa600
Thank you. I'm trying to draw this out now in my head. Any chance you have a pic or can up load pic explaining your solution?
autodynamics
The next chance I get I will go read the wires and tell you what wire needs to remain energized while the high low switch is triggered
It's a simple solution
WHITE AND RED 69
I'll let Pete finish that answer. When I had my HIDs only the low beams worked, but it was a cheap kit. One of these days I will put a new set of HIDs back in.
MackDa600
Ordered mine today. For high n low. Waiting for Pete to hook me up ;)
MackDa600
Pete any update. Got the HID's last week and am eager to get them in...
autodynamics
MackDa600
Ok. I bought the kit with the optional relays as well, so I'm only using the factory harness to trigger the relay rather then drawing off them...
autodynamics
What's your question exactly? Are you adding one or two kits ?
The relays are a must, the hid kits will last much longer with more stable voltages
MackDa600
Adding two kits - high and low.
My question is how to hook them up to the factory wiring to switch on the relays.
Wouldn't all 4 lights be on whether in high or low since there is that jumper wire on the low connector. I'm trying to make them work exactly as they should.
autodynamics
Ok you can install both kits the relay will be done inside at the high beam switch
I will get in my car tomorrow and figure it out
WHITE AND RED 69
Finally got back to work on some new parts and thought I'd post up some photos.
The air grabber is all done and got the lid back from chrome. Was a pain to make work with the RPM intake and had to trim more than I would have liked to clear the a/c but in the end it turned out pretty good.
WHITE AND RED 69
Also got a good deal on another lid so I have one chrome and one orange for a classic look. Right now it's being powder coated orange along with a set of valve covers. Will post up some pics soon as I get them back.
WHITE AND RED 69
Also got a new set of firecore wires and some spark plug looms to help route the wires cleaner.
And got a fancy new billet trunk latch.
WHITE AND RED 69
While the air grabber lid was at the chrome shop I had them re-chrome my bumper guards as well.
WHITE AND RED 69
Finished up the 67 charger arm rest and had it wrapped in leather to match the seats.
WHITE AND RED 69
And added a trans cooler along with a trans temp gauge.
WHITE AND RED 69
 :icon_smile_big:
WHITE AND RED 69
couple more shots of the air grabber lid.
Very clever on the air cleaner.  That car is bad ass!!  :cheers:
kokxville
Your Charger is getting prettier and prettier Clayton  :drool5: :drool5: :drool5:
Nice aircleaner you've made.Looks awesome  :2thumbs:
John
1969 Charger R/T 4 speed A33 Track Pack.
1967 Dodge a108 360 Magnum. Daily driver
1969 Dodge Charger"the car you can take your kids in to school on a friday,go shopping on a saturday,dragrace on a sunday and go to work on monday"
bill440rt
Lovin' the air cleaner, Clayton! Especially the chrome lid.  :cheers:
I've got that trunk catch heading my way, too!  :yesnod: :lol:
Looking real good!
