Defective Ignition Coil?
Started by JRGBoss, May 16, 2011, 11:07:55 PM
JRGBoss
Recently the alternator, regulator and solenoid, coil was replaced on the 68 RT. Starts right up when cold but when you drive it for a while and turn it off it will not start. The ignition coil feels hot to the touch, once things start to cool down the car will once again start right up. Could the ignition coil be defective?
1968 Dodge Charger RT - 2nd Owner
FLG
Could be a few things,
What happens when you try to start it? Does it crank? Hows your timing?
Could be your starter solenoid getting heat soaked, could be you have your timing a bit too advanced and theres simply not enough grunt to get it turned over hot. Just need a few more pieces of info  :2thumbs:
JRGBoss
Quote from: FLG on May 17, 2011, 02:31:41 AM
It cranks fine, just wont start until things cool down a bit.
nascarxx29
Just curious is your ballast resistor bypassed and what brand coil you using
1969 R4 Daytona XX29L9B410772
1970 Coronet RT WS23UOA224126
JRGBoss
Supposedly what was causing it was too wide a gap on the points. Not sure it was related but the alternator was not charging property so it was replaced, again.
nascarxx29
Id change my points to pertronix and use their coil which eliminates the ballast  .As points distributors get shaft play and cause erratic timing  :Twocents:
JRGBoss
Quote from: nascarxx29 on May 19, 2011, 10:55:50 PM
I think you are right. I am in the process of rebuilding my B2 motor and installing the petronix in the distributor. Thereby eliminating the dual points.
Topher
The Pertronix are great, I've had it in my car for 7 years now. The instructions state to leave the ballast in line. Will it fry the coil if the ballast is by-passed?
Topher
67 Charger 383-4spd "the Dawg"
www.headlightmotorman.com
nascarxx29
In think if you use petronix coil you can hardwire the ballast from the back for stock looks
Cooter
Quote from: Topher on May 20, 2011, 09:58:41 AM
Depends on the type of coil you are using...There's ones with an internal "Built in" resistor and regualr coils without...The STOCK coil needs the resistor..
However, you upgrade to say an MSD unit, most times, they do not need the resistor...(Full electronic ignition, and not MSD on point type ignition)
Topher
I used the Pertronix Blaster coil. I made a jumper yesterday and drove the car for 20 miles or so. I did notice a difference. It enhanced a top end stutter/bog thing I'm chasing.
Topher
